1 - 4 of 4 Posts
Screwed and Loving It
This is mainly directed at the mechanical injection folks but may apply to other Pro-Mod type cars.
What size main line to the fuel pump inlet do you run? Do you run a hard line or a rubber line like a radiator hose? If you run a hose, does it have a spring in it to keep it from collapsing? What size is/are your vent(s) and what size is the outlet from your pump to the barrel valve?
I have a 21 gallon Waterman pump that currently has a 1 ¼” inlet and fuel cell that has a 1 ½” outlet and a 90 degree radiator hose (very short) that couples them without a spring. I would think the spring in the hose would cause more turbulence or cavitation than one without it. I use a #12 line from the cell to a vent. My main line out of the pump to the barrel valve uses a #10 line. I've been running this way for quite awhile with no issue - yet.
I hear all kinds of stuff about collapsing a hose to “sucking a hole” in the fuel line to not having enough vent and causing a lean spot. Your would think we would need a 3" pump inlet and a 5" vent to keep out of trouble. I don't want to over engineer as this is not a Top Fuel car with dual 100 gallon pumps. I always think bigger is better or too much is just enough but wanted to see what other folks are running in the real world. Thanks.
Shawn speaks the truth.
Vent is crucial, I actually think we have a 10an vent on our tank. However we only have a measly 18gpm pump.
I don't think the spring in the fuel line would cause as much of an issue as you think Tom, I would not be worried about that.
1 - 4 of 4 Posts
