1 - 7 of 7 Posts
hey all i got a 68 camaro with a sbc and a 4-link backhalf stock front end car should run mid-low 9's what kind of front shock would you realisticly recomend. being a big tire car and kinda slow i'm firguring a DA might be over kill but i don't think the calvert will cut it not being adjustable. I'm thinkin about QA1 single adjustables.
Discussion Starter · #2 ·
forgot to add tires are 32x14 hoosier slicks
Discussion Starter · #4 ·
was 9.60's should be around 9.30's now 2600w/me est. 625-650hp 4.56 gear footbrake car was 1.38-40 60's with a retarded cam(-6*). has stock a arms trick springs and some old shocks have no idea what they are
no one want to take a stab at it
I would put the BNC Afcos on the front if you dont want it bouncing when it comes down and yes its a DA Shock. The weight of the front will be hard to slow down if it gets any air
Discussion Starter · #7 ·
i was affraid you'd say that course it is a 4-link so proper adjustment it shouldn't be liftin much i've never been more then 4-5 in off the ground but the front end it tight might be cause used to have a bbc better check the arms and shocks for bind first
1 - 7 of 7 Posts
