The drive for the distributor and the drive for the cam are now within an inch of each other. No diflection from a two foot cam core twisting between like when the drives are at either end. - front cam drive (chain or belt) and distributor at back of enginePat the distributor is still driven off the camshaft. (At least it is in my LSX Jesel drive). Perhaps I'm missing something obvious here.
yes you can, the bracket sits it up on top of the the belt drive:Can you run a regular electric water pump or do you have to use a remote pump?
it's driven off the crank, cam timing belt gear. As opposed to the worm gear on the shaft, on a bbc/sbc that is all the way at the back. By then the lifters and valve springs have put lots of torsional stress on the cam. Not to mention the slop in the distributor gear and driving the oil pump.Pat the distributor is still driven off the camshaft. (At least it is in my LSX Jesel drive). Perhaps I'm missing something obvious here.
