1 - 3 of 3 Posts
I have a fresh just back from SPEC pressure plate for sbf 10 1/2”
This plate has the billet aluminum pressure ring option with the replaceable friction surface just like on an aluminum flywheel. It has a new diaphram spring as well. Like new condition was a little over $500 new. This plate also does not have any issue sticking to the floor at high rpm. Been on the 2 step at 8500+ and over 9k on shifts without issue. Just rebuilt like new will include ARP pressure plate to fw bolts and also a new throw out bearing. Text for pics 570-394-4272 asking $350 shipped but price is obo... need to sell so make offer.
You can use any clutch disc with this plate that is .350-.355 thick. SPEC can make you anything you need and will cost between $125-$200 for the disc depending on what type you need for your application. Any manufacturer disc will work as long as it is the thickness required. And any manufacturer can make any disc the thickness you need. Thanks
I will sell this pressure plate, new throw out bearing, arp fasteners, pro motion quadrant, upr adjuster, and new cable for $325 shipped obo! That’s one heck of deal
1 - 3 of 3 Posts
