1 - 3 of 3 Posts
I'm running a 72 Camaro with EFI BBC with 625HP on Pump Gas. Running an Aeromotive inline pump and am planning on changing to a Weldon inline pump due to problems with the Aeromotive. I am wanting to keep running a canister type filter or other large filter with an element that will filter better than 10 micron. I am running the filter before the pump and the pump is mounted on the frame rail.
Will a Fram HPG1 flow enough fuel for this application?
Should not run 10 micron before the pump, should be 100 before and 10 after, the fram filter is only rated at lke 90gph max flow rate.
no,the Fram filter does not flow enough,I run one of the old Barry Grant inline filters, get a higher flow filter.My filter is inline an about a foot long -10 an and before the pump.My motor makes about 600 hp,no problems.
1 - 3 of 3 Posts
