I have a 92 mustang I am putting a new 8.8 in it. It had the factory control arms in the rear. I have a 80 capri that I am in the process of backhalving that has solid tubular lower control arms and single adjustable uppers I was going to swap from the capri to the mustang. The lowers bolt up fine but the uppers seem to be wider than the pocket in the 92. Not much maybe 1/8-3/16" or so guessing right now. Are the upper pockets different on different year foxbodys? Most all control arms say 79-93 mustang/79-86 capri. To double check I took the factory one from the 92 and put it in upper pocket in the capri and there is alot of side to side play. Thanks for any help before I order some control arms that wont fit
