1 - 7 of 7 Posts
yeah it can be done . if your good with that sort of stuff .
My question is why would you go through that headache doing that ? that's probably worse then installing mini them selves .
good luck man .
good luck man .
I can get a really good deal on a nice car but in the class I plan on running have to have stock wheel wells. Just trying to feel out if the cost/labor of putting the car back to stock wheel wells is worth it
Sho'Nuff
It's a lil more work putting it back to stock because you have to form up the spring perch's up top and also the upper shock mount unless the class doesn't require "stock location" shocks and allows coil overs in the rear.
Id take a close look into the rules, if the rules says must have "stock wheel tubs" id take the stock tub, stretch it, and put it in. Unless the rules says unmodified wheel tub. just food for thought :)
1 - 7 of 7 Posts
