4th if July weekend pulled my 87 GT outside for a wash, water hose busted didn't wash car.. Went to pull back inside, no fuel pump or spark at coil..
I have replaced ECM, ECM relay, fuel pump relay, wired up fuel pump to toggle switch (pump works)key switch, engine and dash wiring harness. Dash cluster, checked fuseable links, inertia switch, unhooked msd box and hooked coil up factory, Changed out msd distributor to my known good factory distributor, no start, am I missing something? Any help would be greatly appreciated.. Thanks Scott..
