1 - 4 of 4 Posts
10.5 Fox
Rear
Wolfe Double Adj. Upper and Lower Control Arms
Wolfe Single Adj. (weld-in) Sway Bar
Wolfe Coil Over shock mount kit
QA1 DA Proma Star shocks (DD501) w/bearings
12" 150 lbs. springs
Question:
Ride Height
I am having to dial in a lot more right rear spring height adjustment in comparison to the left side just to get the car to sit level, any ideas why I am having to do this? Could this be a potential issue?
No ride height is adjusted with me out of the car
What do you have in the car on the right side? Bottle, battery etc? My fox leans to the right side too, but I suspect its partially due to the battery being there. I am also suspecting a bit of a tweaked axle housing that may be causing a slight lean. That's a common problem in the unwelded 8.8.
1 - 4 of 4 Posts
