Have any of you guys put fox body spindles on a newer Mustang? We have a 95 and know it bolts up but will it affect anything or even work? Thanks in advance.
Just did Fox spindles on my 95. Did the strange brakes and car already had Fox k member with Fox a arms so they did bolt right in. It changed ride hight on my car some raising it up and the steering hadto be re aligned cause the steering arms are in different locations. Glad I did it though. I just needto go with some Fox struts now cause ive bottomed out these sn95 ones trying to get it low enough in the front.
Balljoints actually end up being the same if you're using aftermarket (Team Z, at least) A-Arms. All of their arms use a Fox style balljoint because it is more robust. I asked about getting an SN balljoint so I could use SN spindles and eliminate the need for the spacer and Dave said they're all Fox joints...
Question for you guys running the Fox spindles, which hubs and rotors are you using? I always thought that the SN spindles were superior.... maybe I should save some money and keep my fox spindles.
