1 - 20 of 27 Posts
I have an 89 model Mustang with the factory gas pedal, Lokar cable, and an Edelbrock microswitch. This past weekend at the track I was having to push the damn pedal through the floor of the car to get the microswitch to stay engaged - this was after I bent the shit out of the "arm" on the microswtich in an attempt to help the problem. Is there a better set up out there because what I have will not work. I need less travel in the pedal to achieve WOT and I am not seeing any adjustability in what I have?
I have a lokar cable also and had the same issues. I cut the little ball end off of the cable where it goes threough eyelet at the gas paddle then slide a cable locking nut in place of the ball end so I can adjust the amount of travel I needed (at the paddle). After that I used a large nut & bolt combo as a paddle stop to keep the force off my carb linkage... WORKS PERFECT and cost 4 bucks + my time...let me if you need more detail or pics...
I don't think I understand the problem.Is it more of a microswitch adjustment problem or a cable throttle problem?
It is more of a cable problem - when I adjust the cable at the carb it seems to stretch the first time you put the pedal to the floor. I can achieve the the first half of the throttle easily, the last half is tough. I notched the microswitch bracket to move it back toward the screw on the secondary throttle shft -it helped. I bent the arm on the microswitch and that helped, but not enough. It seems I need more pedal travel.
...failure to communicate
Do you have any slack in the outside part of the cable? In other words, is it just a bit too long? I left mine long in case I wanted to move the pedal and fought all kinds of issues. It was likethe cable was stretching. Made a pass one time with about 25% throttle opening. The issue was the cable sheath would "bunch up." I cut it down to the proper size and never had an issue again.
The stock pedal assembly should have plenty of travel with the Lokar cable.It sounds like you might need to adjust for a higher pedal height,which should get you plenty of travel.I use the Lokar cable and haven't had any problems with getting a WOT with a carb.
the throttle pedal bends sometimes, it has happened to me. i took pedal off and boxed it and tried to strenghten it whereever i could. i had some 3/8th solid rods also i put inside the channel so it would help with the bending. have no issues now
X2 ^^^^^^ what he said............
My throttle pedal was bent when we had this issue.
i had the same problem and from what u are saying its not a cable prob , its the pedal bent , take it off and straighten it out and weld the back of it , box it in so it cant flex, kinda makes it tubular, did mine and never had a problem since, u can also add a rod inside for more strength like (johnquick302)said
moved my micoswitch underdash. mounted on dash bracket near pedal assembly,never had any issues since. cleans up engine area also++ good luck
I'd like to see some pic of this ....Nice idea...
thats not a bad idea but if the pedal is bending you may think your getting full throttle but only getting3/4 throttle.:partyman:
tried to get pics. for you but you really cant see it very well. pull pedal assembly off,make a L bracket mount it on top of pedal .so when pedal is depressed top part of pedal arm will activate your switch. alittle work but kicks ass...
1 - 20 of 27 Posts
