1 - 20 of 26 Posts
Thread killa
04 taurus, 3.0l dura tech, has a bad miss when damp or raining, any ideas??
Coil, 90% of the time, but some were a coil pack and some were individual, gotta isolate which cylinder for Indy ones, if a pack just slap one on. Could be wires also but could were brutal if it’s a pack
Former RJ instigator
Coils or moisture in the plug holes, you'll have to pull the upper plenum to gain access to the rear 3 plugs.
Thread killa
just changed the plugs, two of them had combustion blowing past them, what the hell causes plugs to break like that?
Piss poor design, same as the 5.4 engines that blew the plugs out, they make a helicoil kit to fix the threads if they're stripped.
Trump Voter NRA Member
If it's not moisture in the plug holes there is probably moisture in the connector for the PCM or the main engine harness connector. I've fixed many of these and it can be hard to see the moisture.
Thread killa
Discussion Starter #7
the plug it's self has the combustion coming up between the metal part and the porcilin
Thread killa
Discussion Starter #8
where do I locate these and how to do I fix it?
Your going to have to look, the PCM is usually in the cowl area. They don't put it right on top with an arrow pointing to it, lol
You have to look at those connectors real close to see the moisture, it's easy to overlook it.
Use a hair dryer to dry it up.
Thread killa
Discussion Starter #10
Is it a big engine harness plug?
It happens often, doesn’t mean they’ve failed but it’s not good. It will still run fine and not have a misfire with that issue.
Have you scanned it to see what cylinder? Have you checked spark kv? Do you have separate could or a coil pack and wires?
Thread killa
Discussion Starter #15
coil on plug, and no light on right now...
Get a spray bottle with some salt water in it and spray each coil while it’s running, should be easy to find if one is failing.
will it show even with that big long rubber tube down in the head?
It’s usually the coil itself, but if it’s the boot it will be harder to find. This is why I said to do each one separately, when you spray one and it starts missing-that’s the bad one. Start with the easiest ones and work your way to the end, shouldn’t take much, 2-3 hits. New coil will include the boot
Thread killa
Discussion Starter #20
will do, thank you!
1 - 20 of 26 Posts
