hello i purchased this cam for my 347 and i would just like too know what too expect as in power and sound/idol quality thanks
was this a good pick??? in your perspective???
Cam Style
Mechanical roller tappetBasic Operating RPM Range
3,200-7,000Intake Duration at 050 inch Lift
246Exhaust Duration at 050 inch Lift
256Duration at 050 inch Lift
246 int./256 exh.Advertised Intake Duration
286Advertised Exhaust Duration
296Advertised Duration
286 int./296 exh.Intake Valve Lift with Factory Rocker Arm Ratio
0.518 in.Exhaust Valve Lift with Factory Rocker Arm Ratio
0.541 in.Valve Lift with Factory Rocker Arm Ratio
0.518 int./0.541 exh.Lobe Separation (degrees)
110Intake Valve Lash
0.024 in.Exhaust Valve Lash
0.026 in.Computer-Controlled Compatible
NoGrind Number
RRM-286-296
Cam Style
NoGrind Number
RRM-286-296
