1 - 8 of 8 Posts
just recently purchased 1999 ford F250 super duty has 5.4l motor and is in need of motor i have a 5.4 out of a 99 expedition my interchange shows these 2 motors will not work together. does anyone on here have any knowledge on what the differences are?
Grandpa
They are both windsor eng. but the exped is an f150 based setup, yours is a SDuty. the engine tag #s will be diff. as well. the oil pan,water pump inj etc are all different part #'s. theres prob alot more to knowing Ford:rolleyes:
It will work but you need to change the oil pan, timing cover, and possibly the upper intake. Compare other things side by side. If you want a reman engine I can help you also.
Factory Engine Exchange
800-764-5040
Don
Grandpa
i can swap all that if needed, we have a salvage yard and our interchanges show they aernt same at all i can look it up as long block shows be the same but wont work together
hell go fo it then if you can transfer everything thats different over.pain in the ass,but if you already have it right:)
Simple swap....have done a pile of them.
1 - 8 of 8 Posts
