1 - 14 of 14 Posts
· Registered
Hello Everyone
I purchased a set of 5.29 gears that were lightened, scalloped and Rem processed. Are the teeth on the pinion suppose to be smooth top to bottom? This one has a little step on each tooth at the bottom.
Thanks,
Ed
· Registered
Tough to see but where the surface finish changes near the bottom is where you can feel a little ridge. The portion at the bottom of the tooth is higher than the main part of the tooth. Hope I explained that ok. The person insisted the gears were new and stated some are better than others.
Automotive lighting Finger Automotive design Nickel Tints and shades
· Registered
I would be concerned about strength due to that sharp (?) corner. Can't really tell if there is a rad at that corner, or if its a sharp 90* corner. Sharp would be bad for strength imo.
· Registered
Looks like wear out to that part. Does it come in the original box? Can you see where the bearing has been pressed on? Is there a brand name and number on the ring gear? Brand name or cheap Motive Italian knock off?
1 - 14 of 14 Posts
