1 - 12 of 12 Posts
Just purchased a vega wagon with a 9" it has 4.10 gears. Is there a way to tell without taking it apart if it is small pinion or large pinion. Thanx John
Car has the 4.10s and 33" x 14.5" x 15" hoosier slicks. Will be installing my 600 hp 383, powerglide and 5800 converter. What gear ratio would you guys and gals suggest. plans are to shift at 7000 and would like to cross the stripe at about 7500. Thanx JOHN
Check the pinion stem and nut. If the nut takes 1-7/16" or 1-1/2" socket, it is the big pinion. The small pinion nut is something around 1-1/8" or 1-1/4".
Thanx for the info guys.
Discussion Starter #7
Thanx for the link
Yea, sorry Arron, I have a nasty habit of reading the whole question sometimes.
This would be the question I was refering to. The OP sent a thanx for the link and it somehow offended you enough to respond. I guess you won't get to wear Randy's Halo this month. ...........Toni
Discussion Starter #11
1/4 mile
You need any three of tire diameter/roll out, estimated trap speed, desired rpm, and gear. Any of the on-line gear calculators will then allow you to solve for the one you don't have. Most run best if you calculate the desired rpm at about ~2-300rpm past peak hp. It will actually run higher (which is what you want) when you take converter slip into account. Tire growth is another factor, but it is relatively small and varies with tire type.
Here's my car as an example.
Trap speed ~160
Peak hp @ 6,850rpm
Tire circumference 102"
So if I solve for 7,100rpm (250 over peak hp) I would need a 4.29, which is what I got. The car crosses at about 7,200 so it's about perfect.
1 - 12 of 12 Posts
