1 - 5 of 5 Posts
Here's a weird one
I took my center section apart to change gears.
Some details:
Strange aluminum case (N1904)
Have an old aluminum daytona pinion support (N1927a)
It currently has a timken pinion bearing HM804846 (meant for big pinion) with a collar inside of it.
https://ibb.co/br06d0j
Has a small pinion gears on it now
I want to keep using a small pinion gear.
Is there a pinion bearing that has the same outer dimension as the HM804846(for big pinion), but has the same bore as the small 1.313?
Moderator
No you have to use the bushing.
1 - 5 of 5 Posts
