Just curious if the stock studs that came with my stock/oem housing will work. It's a narrowed 9" with a strange ultra case. Looking at around 1200 hp at the flywheel. Thanks in advance.
Probably OK. To be safe, knock the bottom 4 out of the housing and replace them with grade 8 studs. Weld heavy hex nuts on the inside of the housing and loctite the studs into the nuts.
