1 - 8 of 8 Posts
Grizzly
i bought a truck 1988 7.3 idi with the glow plug controller missing ... i got a new 1 but what side does the yellow and brown wires hook to..:confused: i can tell the yellow is hot constant and the brown is to the glow plugs ,,,what post on the relay do they hook to ..thanks or if anybody has a diagram it would be help full thanks... brian
...the only problem with by-passing it is you need to make sure not to hold the button too long or you'll burn them out.....mine is a crappy design that failed on and burned mine out...most people change to your design because its much better
1 - 8 of 8 Posts
