what kind of max oil temps should be seen on a 6.0. i put a egr cooler delete, a new oil cooler, coolant filter, second oil filter and a tuner on an 05 f350 and when pulling a 14k pound trailer the oil temp will go up close to 230 degrees under a load while the coolant temp is around 208-210. when on flat ground the ect and eot stays pretty close. is this normal for an egr deleted and tuned 6.0?
