1 - 14 of 14 Posts
Platinum Member
What do you keep your heart rate above and how long are you going for?
Cycling, running, etc?
just curious
heck ...............just walking around for me i'm seeing pulse ox at 86-90 percent and pulse rates at 115-125 ,i've got an excuse though i've got a paralyzed r/side diaphragm so i'm only working on 68 percent lung capacity to get o2 into the blood
The guy you don't know
220 minus your age = theoretical max. heartrate
max heartrate x .85 (85%) should be a good place to start.
you forgot where you also multiply by .7 to get your total working range
Platinum Member
Discussion Starter · #7 ·
yeah i stopped running in the hills/mountains on base about a month ago cause i have knee problems sometimes, so now i bike
KEVIN CAPS LOCK
165 FOR 30 MIN TWICE A WEEK
cycling is the best thing you can do if you have troublesome knees. it strengthens all the muscles, ligaments, etc etc without all the pounding that running gives your joints.
KEVIN CAPS LOCK
jfwy kevin :p
I KNOW....CARDIO IS GREAT....BUT CHOLESTEROL LEVELS ARE JUST AS IMPORTANT....LDL AND HDL LEVELS ARE EASY TO MONITOR WITH A SIMPLE BLOOD TEST.
HAVE THEM CHECK YOUR TESTOSTERONE LEVELS WHILE YOUR THERE :p
Habitual Linestepper
I keep it around 190 then cycle up to 200 and then go all out for the last 5min of the 45min program i use, which ends up around 220 before cool down.
1 - 14 of 14 Posts
