1 - 4 of 4 Posts
Is it best to keep the fluid le el on the indicator. Little low or high? It's an aftermarket tube and stick.
If it is a powerglide they recommend 1/2 to 5/8" above the pan gasket on a race tranny, street I would have it at least to the pan gasket
What is the angle of the oil pan in relation to the ground? If its flat , fill to half way up the hatch marks cold running. If its 2 degress down at the front, fill it to the top cold. If its 4 degrees fill it 1/2" over full.
Hutch
1 - 4 of 4 Posts
