I'm using Neil Chance BT and want to eliminate any future thrust issues. I bolted flywheel to crank and put dial indicator few different places..I'm getting anywhere from .050 to .100 runout. I don't know the brand of wheel but it's aftermarket steel and heavy. i then bolted converter to wheel about same thing.
I know the converter moves alot over .100 when running because of wear marks and shims used. The snout moves freely in crank. I know if i buy a new wheel that is flat and the converter goes to flexing i'm sure it's going to warp it again under heat. Should i worry about replacing flywheel? If so what brand for SBF.. Don't need anything fancy looking or high dollar
