1 - 1 of 1 Posts
So I bought this wavetrac 35 spline carrier for my rearend so I can turn some corners and hopefully not break anything.... but it would NOT fit in the carrier.
It turns out that the bearings (3.250" to 3.812" adapter bearings from Mark Williams) on the diff are mounted 3/4" further apart on this setup than the spool that came out of it. So...... I got to bring the unit to the machine shop.
Yanking the thing apart:
Here is the case clearanced and getting milled to work.
He had to cut the cap on the ring gear side of the case as well:
Next was to machine the adjuster nuts for proper thread engagement:
Checking for clearance:
Reassembly:
1 - 1 of 1 Posts
