1 - 16 of 16 Posts
These are supposed to be released sometime early January. Considering pulling the trigger on it. My current setup is a carbed, cam'ed 6.0l with LS3 heads. I was going to go with a Holley HP (as I'm familiar with it, see sig) however this new FITech Ulitmate LS setup looks very promising and my dollar would go much further as the Holley would only be a ECU/harness. With the FITech, I'd have an intake, rails, TB, injectors, fuel pump, regulator, fuel line ect and the ability to control a 4L80 all for either $1745 or $1995.
What do you guys think?
http://fitechefi.com/products/ultimate-ls-induction-systems/
Is there anything wrong with the Holley/EBay intake? I'm seeing them for around $450 with the rails and such.
Some of them come apart under boost.
My brother tried the fitech on E85 and was not happy with it. They told him to add 30 percent more cubic iches to make up for E85. It didnt work right that way. They dont have the software for e85. He has since switched back to gas with it and it is running better but does have a problem holding different maps to the computer. If you have a good tune stored but you want to try different parameter you will loose what you saved and have to start ll over again. He said tech support sucks. He said try the holley system. This is the all in one EFI set up.
Discussion Starter · #8 ·
So far none of the drawbacks would apply to me. Im keeping this setup NA, and I will be running 93 pump. I'm not looking for anything close to max effort and for $1900 or so, this kit seems to have a lot more than most, as long as it decent stuff.
I looked into FItech for my current project. found a lot of guys having issues with the IAC contributing to idle problems that couldn't be sorted. the user friendly aspect and self learning of holley, along with the current "holley days" sale made me pull the trigger on a dominator setup.
Mike
Smoked another CTD
Mike
I recently installed a Holley Terminator in place of a FiTech setup on a SBC with a nitrous plate. Car would never run right before the swap. I wanted him to go to sequential setup but he wanted the throttle body deal instead. Engine does not make a lot of vacuum with it nitrous cam. Probably over cammed. But not any trouble with the Holley and a little work on my laptop. I adjusted the fueling and timing below 3000rpm manually and set the closed loop to start there. Starts right up and idles all by itself now even on a 20* day. Would never do that with the carb or the FiTech. No more mid range stumble.
I set the nitrous up with the Holley also. Now a dry setup with injectors taking care of the nitrous shot. Jetted at 100hp instead of it previous 150hp. Should go just as quick if not quicker now that it runs correctly. Should run low 11s on motor and mid 10s on a 100 shot.
Discussion Starter · #11 · (Edited)
I see your guys point, however the Ulitmate LS setup isn't a throttle body injection like the regular FITech deals, its a mulit-port traditional setup with 8 injectors on each cylinder.
Smoked another CTD
So you put it on and you have an off idle part throttle stumble or it will not idle. How do you fix it? Your options are limited.
With a setup like the Holley you have more options .
Discussion Starter · #13 ·
Point taken. However, the only way the problem would travel over to the setup I'm looking at is if it's in the tuning software as everything else is different. If I had to guess, I would say that the stumbles most of the Go EFI TBI systems are having, are due to poor distribution caused by combinations of only using 4 injectors and whatever intake manifold they are utilizing.
Smoked another CTD
What I am getting at is you can not just get the FiTech software and download it to your laptop. My limited experience with FiTech is it does work that way. Where can you download the software? How can easily alter the tune up manually cell by cell if needed? My experience is you can not easily do that like you can with Holley, Haltech, Fast, BS3, ProEFI, MS3Pro , and so on. If FiTech works, then it is great. If it does not your limited in what you can do to fix it.
The idle and off idle issues can happen with multi port injection also. Very common.
I tuned a 1200hp twin turbo LSX a couple months ago. I had manually tune the idle, starting cold and hot, and part throttle below 3000 rpm. The learning and closed loop worked great above that RPM but not so much below.
My advise is find a tuner in your area that has a good reputation and see what system he prefers and go that way. Do it once and be done with it.
Discussion Starter · #15 ·
I tune my own stuff and while I'm no expert tuner by any means, I get by (see sig). I know FiTech has the ability to be tuned by laptop, however, I haven't been able to find the software downloadable online. A buddy of mine has an SBC with a Go EFI system on it and I'm going over there tomorrow to look through his software on his laptop and see how it compares to what I'm familiar with, which is Holley and some BS3 along with HPTuners.
I looked at the FAST EZ EFI 2.0 LS kit which is around $1440 but you still need an intake, injectors, TB, fuel pump, lines ect which would put total investment well over the $1995 for the Ultimate LS system.
For this setup, again I'm not looking to push this NA LS close to any edge. I'd just like a simple system to hook up, let it do most of the tuning and give good driveability.
Smoked another CTD
I tried to get the software myself for FiTech to fix it before removing it and going Holley. You can read online of guys with similar issues taking months to get a copy of the software and base calibration. That is why it was removed and replaced with the Holley. I did notice the Holley HP is your sig. That is why I recommend going that way. I had no way to tell who tuned but I could be reasonably certain someone near you could tune it. So go that way. The path of least resistance and the far better customer support the Holley system offers.
1 - 16 of 16 Posts
