1 - 15 of 15 Posts
Sound Good let us know the Numbers
Discussion Starter · #4 ·
It made 1253 hp at 6400 rpm and 1161 ft lbs at 5900 with 17 psi. The dyno room got extremely hot and we decided to wait until Tuesday to finish. It should easily make over 1300hp. What are your predicitons 1/8 mile e.t. and mph? 3000 lbs 1970 nova on 29/10.5, 3.73 gears, 400 trans(powerglide later), stock frame rail and ladderbars.
Discussion Starter · #13 ·
No special mods to carb, no boost ref fuel regulator, and no BOV. It is 8.5:1 with carrillo rods, LA enterprises crank, CP pistons, CNC ported BB2 xtra, shaft rockers, jesel belt drive, Vacuum pump, and a BLP 1500 cfm carb. It made 1061 ft lbs not 1161 ft lbs.
workin it
Most bitchin!!! I certainly hope it doesn't backfire though...I would hate to see that carb landing down here in Texas...oh wait, yeah I would, I could use that carb;) Good luck and keep us updated:smt023
1 - 15 of 15 Posts
