1 - 18 of 18 Posts
yesterday i was running my valves on my big block
and noticed gold dust in the oil on the head
really fine not a lot just noticed on my iron heads
had to dip my finger in the oil and look at it
what could it be(hope it is not the bearings)
and why on top
just changed from castrol 10 -30 to mobil 1 5-30
filter was clean from last oil change
oil pressure is good no funny noises
im not running a bronze gear
please help
bronze intake valve guides ,
Whats going on down in Monexico?
i dont know dont get out much
just playing with (oscar the grouch) green nova
always something
do i just need to keep an eye out.
check filter
You could pull a couple of the valve springs (with the piston at TDC) and move the valve back/forth to see if the guides are loose. Valve has to be off the seat a little though. If they are they'll probably start wiping out your valve job if left unchecked. Is your rocker geometry correct (ie in relation to the valve tip)?
Craig
always something
check filter
Do you know Jim Vincent that was in the Army @ Ft. Leavenworth? Had a 68 Camaro (Green Hornet) with 502 ran 11's.... maybe 12 years ago.
the guids would have to be wasted and most of the material would go down not up// if the filter is clean the upper end stuff could be shim material if the shop didn't put a hardend shim under the spring will eat in to the shim most of the metal will stay up top. the dampner will saw through the shims... 2cts?/
Senior Frog
GOLD DUST=BRONZE
Bronze Gear.?
I had gold dust in my motor for a while because of a gear fittment issue ( it was tight) now its cleared up after a few oil changes since the gear wore itself into position.,...Gold dust is definatly not bearing
(bearing would be silver guys)
Addicted To Nitrous!
Make sure you dont have an inner valve spring broken, look at all the valve springs and see if any show more signs of the gold dust, if so thats the bad one. Could be the spring broke and rubbing the guide. I have had this happen twice.
Discussion Starter · #12 ·
yes i do
i am actually running the crank out of that 502.
Discussion Starter · #13 ·
yenko69 i will check with the machinist before i start tearing apart
gimmemud i will check for broken spring
excellerter iam not running a bronze gear
but also thought it would have to be silver before a struck gold
thanks so much
yes i do
Tell Him Scott (butler muffler) from Leavenworth said hello and hope all is well! Lost touch with him....one hell of a guy met his son once too....Nathan can't remember for sure , their stuff ran like stink back in the day but that was when 10's and 11's were FAST!! SORRY FOR THE JACK!
Discussion Starter · #17 ·
muffmanscott
if i see him anytime soon i will let him know
i havnt got to the races or cross paths with him for some time know.
Doesn't Jim Vincent own the drag radial malibu that Merriman drives?
If so its an 8sec ride now, no more 10-11's.
that is correct craig
1 - 18 of 18 Posts
