Filter th 400
532 Views 6 Replies 5 Participants Last post by  Farrer-Out
I have two different any of them better or are both ok to use? Street/strip build that will sit behind a BBC with 600-650 hp 3500 in stall.
See less See more
1 - 7 of 7 Posts
Do not use the one on the right, they restrict flow and can get plugged up. The one on the left is the ticket.
  • Like
Reactions: 2
Ok just what I thought! Thanks!
I just went through this with my trans guy.
As a favor he had me driving all over town looking for a special 400 filter that didn't have the fiber material.
Using a special truck number that was supposed to be for the good filter every damn store did a switch to the cheap filter when you showed up.
He had ran out and had an overnight repair and needed that filter.
I believe he hates those fiber filters so much, he put a used filter in before he would use the new fiber material filter.
Good luck.
See less See more
Brass screen 400 or AT 540 Allison filter - 34010B
  • Helpful
Reactions: 1
58890 WIX number
Available at most any chain parts retailer
1 - 7 of 7 Posts
