1 - 2 of 2 Posts
Anyone do this successfully? I want to attempt this run all filled. Block and heads. Use Moroso block fill or Hard Blok ? Is there another product avail that will work with cast iron?
I'd like to eliminate cooling system hardware. 3 minute run time on\off throttle. 1000ish HP methanol\10psi. I can use any of the 70's iron heads to keep expansion rate same as block. Or even use aluminum heads... O ring copper gasket setup.
1 - 2 of 2 Posts
