We can not get any fuel on the plug. Our .36/.28 14* tune lost 8mph with same timing and fuel pressure. Carb seems to come up clean patrick just went through it. We changed regulators, cleaned the tank. Pro 500 pump, haven't checked gpm but seems to flow plenty volume into a bucket and pump goes into bypass at 25 psi. 8 psi on carb.
We put a .28/.20 16* in it and it picked up 3mph from above kit but plugs still don't have any fuel on them even at 6.5 lbs flowing. Took fuel solenoids apart and everything looks good.
Using a eddy progressive and 7531. 12v no alternator, new red top. I think the next thing I am going to do is power everything up and dry fire the kit and see if I am getting proper voltage at fuel solenoids from the progressive. Anybody else have any ideas?
