1 - 20 of 57 Posts
Looking for a nice 4” cowl hood for a 93 firebird, extended to the windshield. I typically use hardwood. They don’t make one any recommendations?
GlassTec produces excellent quality fiberglass components.
Does VFN make a Sunoco style hood for that? They did for my 4th gen Camaro
They do.
Mine fits like shit. Mine is hinged with a front latch. Granted this is probably one of the hardest hoods to make but still. I'm going to have to re-break the headlight cover areas and cut a relief area in the center of the hood outside of the hump to bend it, then fiberglass it back. I also had to cut the back support so the hood would go down in the back. I will have to make a support across the back as well. And yes, I have all my adjusters etc. I expect some work, but not this amount.
Maderator
They do.
Ya mine took quite a bit of work as well, mine was a dzeus on, I actually used steel rod and bent it to the contour of the fenders and glassed it in to the underside so it would hold its shape.
Regulator
They do.
When did you purchase and from whom?
Regulator
PM me your # and I will text or call you in the AM! Your choice call or text!
1 - 20 of 57 Posts
