1 - 10 of 10 Posts
Looking to upgrade my 8 point to 8.50 cert .
My questions are the welds aloud to be ground ? Reason is they have been cleaned up ..not by me
And sec question CAN I re weld over them .?
7.86 @ 8800DA 3365lb 275s
i think in general most guy's mis take the "no grinding o welds" rule. i think it's intended to mean grinding to make them appear better is unacceptable. i don't see where grinding out a shitty weld and rewelding it is against the rules.
Discussion Starter · #7 ·
So i can grind a little on the welds clean them up more and make another pass ??
and this is ok ??
Discussion Starter · #9 ·
another ? is it safe to assume no paint on the chassis/bars before inspection..
I should just order the rule book ..haha
there is no issues with painting before hand just means you may need grind the paint if it doesn't cert.
1 - 10 of 10 Posts
