Anyone use them? The 4.205/.035 interests me.
THANKS
THANKS
Have not had much luck with them Chad. Is that the one for the SBC ? I tried it about 5 years ago and couldn't get them to seal right,I know a couple others that had the same results. I also used them on a 2.0 Pinto engine and at 10:1 comp it was pushing past the fire ring into the crankcase.I think they changed something.I do some 2.0 stuff for SCCA racing and they had an approved gasket.I spoke with a couple other builders that were using them and they had the same problems,we all stopped using them.Don't know if you would have better luck or not.
Chad, call Brian at dakota parts. He is a real straight shooter. I am sure he can give you the low down on them.
Keith
