1 - 5 of 5 Posts
Just wondering how I stack up?
I went 1.14 3.18 4.900 at 146.5 and 7.688 at 172.5
Motor is a 496. 427td block, Merlin heads, box stock victor 454r intake. 1050 carb.
Tune up is .061N .046F 5.25PSI off the brake then the DP at .01 delay .030N .024F at 5PSI.
16 degrees total. The best part is the plate shuts off at 5 seconds into run. The car really falls on it face when I do this(hense the low MPH)
Combo is a 2650 pound chassis car. 32X14 tires. 1.80 glide 4.10 gear. Tight converter. Stalls at 3650 flashes to 6100 on both kits. Shift at 7000 go through traps at 7450.
I know there's still tons of room of inprovement yet to. Low .60s pretty easy maybe a high .50 if I lean on her and run the plate out the back door.
That's rollin for a 496 bro no question. Nice numbers.
1 - 5 of 5 Posts
