1 - 11 of 11 Posts
i have a 95 mustang gt and i was wondering other than the things my car has already what else should i look into to make sure i can put the power to the ground...
900 hp turbo car powerglide with transbrake would like to do it on 275 drs shooting for 5.50,5.60 8th mile
sub frame is tied
upper lower non adj control arms
lake would 50/50 rear shocks
trick springs rear
air bag passenger rear
8.8 rear end 31 spline axles 5/8th wheel studs
full spool
ta girdle
tubular k member and a arms
coil over front
cast and camber plates
8pt roll cage
and thinking about running my aluminum drive shaft
Boss
Swap out the non adjustable suspension for something that is adjustable. I don't see it listed, so I'll throw it in there, a QUALITY anti roll bar. Then look into gettting a set of adjustable shocks/struts. Call Dave @ Team Z or Mark @ Racecraft. Both companies offer superb products and customer service.
Agreed you have a suspension on the car that I ditched when I started running 11.50s in the quarter.
ARB and adjustable suspension as a bare minimum starting point.
Oh and ditch the trick springs and airbag.
X2
Adjustable uppers/lowers
Lower control arm drop brackets for housing
Anti roll bar
Adjustable shocks
Would also suggest moving spring off the lower control arm and going with a coil over set up.
Your going to want to get away from anything that is urethane in the rear.
You can call and talk to Pat or I if you have any questions. P.S. Mark is no longer with us at Racecraft.
Thanks, Kory
Boss
X2
Anti roll bar
Adjustable shocks
Thanks, Kory
Sorry Kory. I wasn't aware Mark was nolonger with the company. To the OP, true coil over setup in the rear will make an improvement as well.
x2! also those 31 splines wont last long either. You sure that motor is 900 horse? If in fact it is, almost all of these parts you have are doing you no good.
And if you're going to buy new rear shocks, coil-over or not, if you plan on running 275's... save up the extra $$$ and go with a double adjustable rear shock right away. It'll save you lots of headaches.
I have a similar car with less power, 5.50 to 5.60 should be prety easy, with just some good suspension parts and some adjustable shocks, get some good adjustable uppers and lowers a good ARB and some adjustable rear shocks, I use a stock V8 spring with one coil cut and the strange 10 way boltin shock, I've had real good 60 foots on a decent track, and never been out of the .20's on a test and tune track! Keep it simple and have fun!
also depending on where ur racing ur shooting for bout a second faster than ur cage allows
You can find me here.;)
1 - 11 of 11 Posts
