Installed a FAST crank trigger kit on a vehicle with a 7531 box. Came with a pigtail to plug the sensor right into the MSD harness. No fire. Can plug the harness into the dist and fires right up. So that should narrow it down to the pickup I think. I've got the pickup darn near centered and have had the gap from .030-.060 with no luck. We had powdercoated the pickup mount so I tried externally jumpering a ground to see if that could be an issue with no luck. Any suggestions? Thanks.
