1 - 8 of 8 Posts
Is melting of the dash switch and or plug from the wiring harness a.common problem. I have 1994 f350 that I got and smelled burning wire type smell off and on. I was finally able to tell it was coming from the light switch. When I took it out the plug from throw harness and wires behinfd it were melted. There was shrink wrap and you could tell that the plug was replaced at some point. I was going to go to the bone ward and cut a plug out and was curious if this is a common problem and if there is a fix.
pretty common problem on the pic-ups, esp if you have extra load on the lighting circut via more lights & lamps, go-to the dealer and get a new switch and pigtail asbly and you should be good.....
seems that the late 80's era had more issues with the switches overheating.. most is caused from bad grounds. also many have cured issue with a larger relay to turn off or on and send power to the headlamps.
whenever we add side lights to the cab or running boards we add a relay or a totally seperate switch.
having the heater duct right next to the wires does not help.
Got the switch and wasnt sure if I could get a harness. I took about 20f'n lighst off the truck after I got it but the damage was probably already done, I have about 10 more I can loose without a problem
You can buy the harness pigtail at most auto parts stores - Pico P/N 5311C. I burned up 4 of them with the extra load from my camper and 32' trailer, finally wired the headlights from relays fed directly from the battery thru auto-reset circuit breakers, cured the problem and my headlights are brighter as well.
Discussion Starter #7
Thanks for the info. Sounds like a solid plan. Glad to here it is an easy fix.
Discussion Starter #8
1 - 8 of 8 Posts
