1 - 6 of 6 Posts
i have a f2 with a ford bracket for head hook up. I need a bracket for a sbc the ford all most fits its off a little. do u guys buy new and were. I called super chgre and they said 3k for crank mount. I trying to find it alot cheaper.
Couldn't you just make (or have someone make for you) and adapter plate that bolts to the sbc head with holes for a sbf patter tapped into it? It would move the blower out away from the engine maybe 1/2" but should work and would be cheap.
Thats what im going to do make ford work. Where can i get a crank pulley (sbc) the top pulley is a 50 tooth what will i neeed for bootm a 73 tooth. Its a cog belt said up. Trying to running in 8s.
I have 2 procharger SBC 77 tooth crank pulleys one of them has the v-belt pulley molded into the back of it the other is just the crank pulley. pm me interested. $50 + shipping.
If your blower is clocked for the Ford bracket already Procharger offers an adapter bracket to bolt the SBF bracket to the SBC. Its generally used for 3rd gen F-body applications. I've gotten a few of these for guys in the past.
1 - 6 of 6 Posts
