Hi guys I need some solid info please as I am about to buy a F2 head unit...
My current set up sbf Windsor 435ci tfs r heads 368int/268exh I run c16 4" piping with a frozen boost 2000hp W/A cooler my F1r is an old 5.0 step up with 77/48 cog and I spin the motor 8000-8200rpm and I see 16-17psi ..
This is a a CSU blow thru dual seats carb set up... Best ET is so far [email protected] with only 23 total timing... If I upgrade to the F2 and use 66/48 pulleys I am I going to pick up ..?
Anybody ..?
Thx
Is the bigger blower with less impeller speed better than the smaller blower with more impeller speed ..?
Anybody ..?
Thx
