1 - 10 of 10 Posts
Has anyone tried or know if I can run this blower with a standard sb crank snout with a single keyway? Its on a 15* headed 427 with an ATI balancer. Thinking about running a race or two like this. It's set up for turbo and just want to throw the F1 on and go. Thanks
Dont do it ,double keyway a must on any cog drive,will cause loads of damadge if it lets go.You can buy a double key crank kit which means you dont have to pull the crank,also ATI do a nice aftermarket double key damper hub.
Where can I find that kit? I can get someone local to broach the dampner.
Thats pretty cool. Thanks for the help.
not sure how it would work, but on the LS engines with the stock balancer(pressed, no keys), they drill between the crank and balancer,
and slide a round piece in-that might hold along with your stock keyway
i have over the years run 1 keyway with roots blowers, and ran 18 lbs with a procharger with a serpentine belt no problems
ATI has a kit to drill the crank on LS cranks, not sure if they have something for a s/b to make a sec keyway-it would have to be 180 deg
from the ext one, pretty accurate
i think Procharger has the LS kit with the balancer installed
i always have my balancers hone fit for proper press, that helps too
Custom Engine Shop
I would recommend against the single. No need to trash a good damper. Also if it is an ATI make sure it has a Steel hub not an aluminum........
You'll need to upgrade your Damper Hub. I found out after splitting a couple ATI standard hubs.
The early small block Chevrolet and the later LT1 and LS1 engines all present problems when supercharging. The original Small Block and the LT1 have a shaft size of 1.245” and a seal diameter of 1.760 leaving the hub wall thickness at .257” or just over 1/4”. Many engine builders put a 1/4’ key in the crankshaft leaving just 1/8” of material between the groove and the seal surface. The result is a failed hub that destroys the damper and the nose of the crank shaft. The later LT1 and LS1 are even worse with just a press fit and no keys; a total disaster when you try to supercharge and drive the blower from the damper. To remedy this situation, ATI now manufactures a variety of Small Block Chevrolet hubs for supercharging.
Big Block 2.331” Seal Diameter
For the serious racer with high boost requirements, ATI offers a small block Chevy crank hub with the big block 2.331 seal diameter increasing the wall to .562; a whopping 220% increase that totally eliminates failure at this point. A new timing cover and seal are required. For small blocks up to 1992.
Applications
Part #
Price
HUB FOR SBC, 6 BOLT, CHRYSLER FRONT, (1) 3/16, (1) 1/4 KEYWAY*
916135​
$141​
HUB FOR SBC, 6 BOLT, CHRYSLER FRONT, (2) 3/16 KEYWAYS*
916136​
$130​
HUB FOR SBC, 6 BOLT, CHEVY OEM FRONT, (2) 3/16 KEYWAYS
916172​
$150​
TIMING COVER FOR SB CHEVY, WITH BB SEAL, CAST ALUMINUM
925500​
$150​
HUB FOR SBC WITH BB SNOUT - CHRYSLER FRONT - 3/16" & 1/4" KEYWAY
916134​
$141​
*Room in front of damper for ignition trigger wheel located on hub
1 - 10 of 10 Posts
