1 - 3 of 3 Posts
Not sure if this is the right place to post this or not but I have a 97 camaro it was originally a v6 auto car. I have a th400 and lr4 going into it. Few questions.. I need a dash/body harness. What years are the same as my 97? Im not running most stuff so a v6 harness will work, just unsure of year compatibility. Next question is wirinf the reverse lights with a th400/ b and m ratchet shifter. Cant seem to find much info.
Thanks in advanced for your responses.
As far as the dash goes... What gauges do you want to work?
What particular B&M shifter do you have? The Pro-Ratchet shifter has a reverse light switch built in like some others, but some dont so...
Im not sure which shifter I have I cant remember but it does have the switch built in. As far as gauges go im running a standalone psi pcm and all aftermarket gauges like aem eugo aem oil pressure and aem truboost. Im running a cable speedo ans I am running a tach.
1 - 3 of 3 Posts
