Status
Not open for further replies.
1 - 4 of 4 Posts
Is anyone using one of these? Any pics of them installed?
Is it only for the radiator in the stock location, or can it be used with it stood up?
I will be using something like the Griffin rad and standing it straight up to clear turbos.
Thanks,
Greg
Ya know, we've only sold a few of these and I haven't seen a single one after installation. We build them to be installed only like the factory piece, however, if you let me know you want to use it vertically at the time you order, I'll make a note of it and add enough core and layers that it can be used structurally. It won't be much lighter than a steel piece, but it will be stronger and should serve your needs perfectly. And just like all of our other stuff, if you use it and it doesn't hold up or shows signs of stress, I want to know about it. Send it back and we would fix or replace it free of charge.
Awesome, I'll get with you when I get the rad stood up so I can get measurements, etc.
Thanks man!
1 - 4 of 4 Posts
Status
