1 - 5 of 5 Posts
Has anyone put the long 1/2'' studs in the stock front hubs of a 98-02 Firebird ? If so, i need the part # for them. Thanks
Yes I have.....don't have a part # for you though sorry. Their metric....12mm though.
I need 1/2'' standard thread. Need the longer studs for Bogart wheels. Did you have to drill yours out or is that the stock size ?
I bought longer metric replacement studs in the stock size. Knock the old ones out and press new ones in. You can usually get them at any parts store like NAPA etc. If you want to go to a SAE thread then you'll probably have to drill the hub out some. But then you could probably use any long 1/2" stud too (moroso, arp, etc.).
Ok, i think i'm gonna measure hub thickness and just order some ARP with the proper length knurl, and drill them out to size. Thanks for the help.
1 - 5 of 5 Posts
