1 - 2 of 2 Posts
LP-25.com
$1,160 SHIPPED.
XFI box was my race spare. New dual injector driver motherboard installed from F.A.S.T. Has datalogging option. Pic details attached.
Only requires a download to be the latest 2.05 version.
NEW: XFI main harness, V-8 injector harness, 5 datalog sensor harnesses, Wideband harness, Calport harness.
CO2 boost control valve wired in.
Sensors brand new. Some installed idled but not run: 5 bar MAP, water temp, IAC, TPS, 4 Wide band O2 (2 new in box) several typical fuel and oil PSI one of them 0-500. Spare inductive crank trigger pick up sensors. More also see pics.
Miami, FL 918 two six nine 8084
Also Available For Sale : Ask for pics
These parts are NEW were installed started and idled.
8 NEW precision Turbo 225 lb/hr low impedence injectors $990
Custom billet HE GM V-8 Cam Sync with slip collar and composite gear $190
NEW Custom heavy wall 304 Stainless turbo Headers SBC NEW a work of art $1,900
Belt Drive Enderle 990 with electric prime pump and Magnaflow bypass regulator. $600
NEW 3GPM manual injector system CO2 operated on off valve distribution block hoses and Gorr nozzles. Plumbed into Wilson elbow base. Elbow not included. $225
NEW System 1 EFI fuel filter and mount. $200
NEW Procharger Red Race BOV $390
NEW 16 Volt Racing Battery and Alternator $440
1 - 2 of 2 Posts
