1 - 6 of 6 Posts
Ok so right now I have a D1SC bracket on my BB with an F1-r 12 rib, my guess is its really old cause its single braced I want to move up to a F-2 bracket just wondering about placement in the engine bay and pulley allignment, I already have the valve cover notched and I had to concave my fenderwheel I was hoping it would be a direct swap if not I was just going to get a double braced D1Sc bracket. thanks for any info
thanks for the response its a bbc in a 71 chevelle, I guess Ill find out cause I ordered the bracket today.
I got the bracket in and the blower setup like d1sc to the right and the f-2 bracket mounts on the left, wich leaves the ID tag pointing toward the ground, do I need something to mount it like the d1sc says the tag is to be mounted face up?
The tag needs to be pointing up for the oil slinger inside to work properly. You may have to send the blower in to have it reclocked.
1 - 6 of 6 Posts
