1 - 5 of 5 Posts
Anybody running an external wet sump oil pump on a mod motor? If so, just wondering what you're using, how you're driving it, and how it is plumbed.
MMR sells a kit with an avaid external pump. It comes with an adaptor for the block with all the fittings you will need to plumb it. Same kit we run on all our race cars. I dont think its listed on there site but give us a call on Monday and we can set you up with all the componants you will need to make the complete set up work. 805-383-4130
i have the mmr on mine has been running for 2 yrs. but it did have a failure this year. the internal pin came out and locked up the pump. this pump is the moroso one and when i sent it back to moroso for them to see (because they said that couldnt happen) he called and said it would be fixed and returned with no charge,and it was but it didnt help the fact that it screwed the crank up.
1 - 5 of 5 Posts
