1 - 4 of 4 Posts
I think that I want to move my turbos up front to get them in a better possition.
They are B/W S491 turbos from Bullseye with the S6 flange 1.45AR.
The header pipes ar 2 1/8" outside = 2" inside
If I build a new set of headers facing forward and move the turbos up front, what size to use in between the headers and turbo flange ?
Will a 3" do the job or will it need a 3.5" pipe ?
Motor is at 505cui on methanl with aprox 3000hp @ 40psi.....
Picture of motor with the old manifold and 88mm turbos, but the headers are the same.
Custom Engine Shop
3.5" is a much easier fit to a T-6 flange!
mfi turbos rule
wooohoo
mechanical fuel injection
chubby time....
1 - 4 of 4 Posts
