1 - 6 of 6 Posts
What does it mean when inside exhaust has white residue? Lean or just the fuel I’m using cause it? I use Sunoco 116 maximal.
Maximal does it. I have same in my exhaust. But you should still be checking plugs or A/F to be safe.
When I used to run my car on a chassis dyno, the pipes would be white inside after the end of the run. The infra-red said I could've added more fuel but for up to a 30 second blast, it was fine.
Can't speak to the mzximal but Torco with nitrous used to leave a cigarette ash like deposit pretty similar to what you have except slightly gray.
1 - 6 of 6 Posts
