41 - 48 of 48 Posts
Discussion Starter #41
Thanks guys for all the input.
After changing diaphragms in the regulator on the bottom of the pump and the regulator by the carburetor and playing with springs and testing all that I can – nothing seemed to change.
However, once the ambient temperature changed from the 60s to the 80s, the fuel pump would spike to 11 and then settled to six more quickly as to avoid bending the float tabs and flooding the motor.
Several years ago, Mallory tech was very hard to access and Mallory was then bought out by MSD to which now has been bought out by Holley and there is no tech support for this pump – you can just buy a new one if you want.
Decision: is to run it and see what happens.
Thanks for all you guys help – take good care, Craig
Long Live The King
Is it really worth the damage that could happen with running a defective fuel pump ?
Discussion Starter #43
Good point if it appears to run lean - I would change it - although I have to think twice about the $610 with my job being severely cut back.
Thanks, Craig
Discussion Starter #48
Hey Nice Chevelle and Mav (I had a 72 Maverick and loved it!),
Thanks guys I will look - into the check valve deal.
Take Care, Craig
41 - 48 of 48 Posts
