I have been struggling with this lately, my exhaust is extremely hot just cruising around like normal (street vehicle). I have a TGT probe just prior to the turbine flange. Idle is around 800-900F with around 30 degrees of timing. Light cruising at 75mph in OD at ~2400rpm is around 1550-1600 degrees. All pre-turbo pipes are doubled wrapped and the turbo has a blanket, but even when they were not wrapped temperatures were around 1450 degrees. Timing at cruise is 45 degrees. And fueling is pump 93 closed loop at stoich.
I know low timing will cause excessive heat, but 45 degrees seems like a lot of timing to have this issue. Setup is a 402" LS with BW s400 82/96 turbo with 5" dp. Cam is a 230/233 114+4. Has anyone had to run more than 45 degrees during cruise to keep EGTs reasonable? Having the turbine glowing under the blanket at light cruise is a little excessive IMO.
I have a temp gun and at idle the temps are close so I trust the sensor, plus its a pretty new. I saw something about installation depth being critical, I have it roughly to the center of the pipe, not sure if this is correct for the autometer gauge or not.
Hard to tell temps under boost, too many other things to look at, but I suspect around 1800 or so. I use pump 93 mixed with c16 at the track and I use 100% meth with 2 15gph nozzles above 5psi.
